Activity › Forums › VEGAS Pro › No External Preview on Vegas 10
  • Nigel O’neill
    May 29, 2011 at 3:25 am
    This article refers to multi-camera editing, not the external display monitor setup.
    Follow this from the Sony Vegas help
    From the Options menu, choose Preferences and then click the Preview Device tab.
    From the Device drop-down list, choose Windows Secondary Display. The Details box displays information about the device.
    From the Display Adapter drop-down list, choose the device where your preview monitor is connected.
    You can click the Identify Displays button to determine which display corresponds to each setting in the drop-down list. A number will be displayed on each monitor.
    From the Display Mode drop-down list, choose the frame size and refresh rate you want to use for the secondary display.
    Setting
    Description
    Use Current Settings
    Video is displayed using the monitor’s resolution and refresh rate specified in the Windows Display Properties control panel.
    Automatic Size Settings
    The software will attempt to choose the optimum resolution and refresh rate. This setting overrides the Windows Display Properties setting as long as the secondary display window is active.
    Pick Custom Settings
    You can choose the resolution and refresh rate you want to use. This setting overrides the Windows Display Properties setting as long as the secondary display window is active.
    Select the Scale output to fit display check box if you want the video preview to fill the display.
    Select the Apply deinterlace filter check box if you’re previewing interlaced video on a noninterlaced display. This filter can reduce the artifacts you often see on the edges of moving areas.
    The Apply deinterlace filter check box will be unavailable if your video adapter does not support pixel shading.
    If you want to adjust color reproduction for video previews, use the color management controls.
    Select the Use color management check box.
    Select the Use Studio RGB check box if your source media conforms to studio RGB color (black=16 and white=235) and you will be previewing on your computer’s CRT or LCD monitor. When the check box is selected, the studio RGB range is expanded to 0 to 255 to conform to a computer display.
    Clear the check box if you will be previewing on a TV monitor or if your source media does not conform to studio RGB color.
    From the Monitor color profile drop-down list, choose the color profile that best matches your display.
    You can obtain ICC/ICM color profiles from the display manufacturer, or you can create your own if you have a calibration system.
    The Use color management check box will be unavailable if your video adapter does not support gamma adjustment.
    Select the Recompress edited frames check box if you want to recompress edited frames in your project before previewing. When the check box is cleared, edited frames will not be passed to your preview device.
    Select the Display frames in Video Preview window during playback check box if you want to preview on the secondary monitor and in the Vegas Pro Video Preview window simultaneously.
    When the check box is cleared, video is sent only to the secondary monitor.
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Sebastien Gravel
    May 29, 2011 at 2:39 pm
    Well, I did a reset to default settings then followed each step as you outlined and it is now working. Wish I knew what was wrong, but at least it’s working!
