Activity › Forums › Sony Cameras › No EX option in FCP Easy Setup
Posted by Max Morse on October 13, 2009 at 5:59 amSo I’ve been trying to edit footage on my laptop (Macbook Pro w/ FCP 6.0.6) from my EX-1 and for some reason the correct EX formats are not showing up in my setup options. I can only choose the Sony XDCAM HD options, bc the HDCAM EX and XDCAM HD422 options are just not there in the drop down. Am I missing a codec or plugin or something?
Thanks for any help ….
max
Max Morse replied 16 years, 11 months ago 4 Members · 12 Replies -
Rafael Amador
October 13, 2009 at 3:47 pmHi Max,
I’m not sure but I think the Easy Setups get installed with the SONY TRansfer and the FC Plugin.
rafael -
Craig Seeman
October 13, 2009 at 3:54 pmEasy setups for EX should be there with FCP 6.0.2 and up. They’re built in. That said, this is an oft reported issue. I can’t quite remember what the fix was but it might be a reinstall of Quicktime and Final Cut Pro. It might be an uninstall and reinstall of FCP. It might be trashing FCP preferences. It might be adding the above as Rafael mentions that jogs FCP’s “memory.” They should be their with FCP 6.0.2 install. I think sometimes the issue happened when updating from FCP 6.0 or 6.0.1 to FCP 6.0.2 and up. It’s a flaky but common issue. I just wish I could recall the voodoo that fixes it.
Frank Steffenhagen
October 14, 2009 at 5:51 amIf nothing works, you can always create a custom setup yourself,
name and save it. It’ll appear inside the easy setup dialog box.Frank
Max Morse
October 14, 2009 at 6:45 amthanks for the help, guys. and i’ve tried the custom setup but i still get extra rendering time when it says “conforming mpeg-2 format.” any other ideas? i’m fearing a re-install may be in my future …
Rafael Amador
October 14, 2009 at 9:37 am[Max Morse] “i’ve tried the custom setup but i still get extra rendering time when it says “conforming mpeg-2 format.” “
What means that?
With the Conform functions in FC, the Easy Setups have become almost unnecessary.
Rafael -
Max Morse
October 17, 2009 at 5:32 amHey all …
So I’ve tried just about everything suggested. Trashing receipts, reinstalling FCP, and reinstalling all the XDCAM products I could find (SxS driver, Log and Capture plugin, XDCAM transfer, browser, etc.). And still no EX formats in my setup. Any more ideas? Do you think the next step is going to see a genius?
mm
Rafael Amador
October 17, 2009 at 6:13 amHi Max,
Go To Applications> Final Cut pro Additional Easy Setups> English.
Scroll down and look if is over there.
rafael -
Max Morse
October 17, 2009 at 6:36 amrafael! there they are! now any idea how to get them to load into FCP? thanks so much!!!!!!!!!!
Max Morse
October 17, 2009 at 6:47 amnevermind, rafael … i was able to figure it out. and now it’s working! thanks so much to everyone for their help!
mm
Rafael Amador
October 17, 2009 at 8:44 amHi Max,
From FC 6 on there is a kind of Easy Setups manager.
Open the Easy Setups window and select:
Format: All formats
Rate: All rates
All the easy Setups that you have should show up on the Sequence Preset.
I have Easy Setups in four different places on my System.
Rafael
