Activity Forums Apple Final Cut Pro Legacy No DVCPRO HD Audio output to HD1400
  • No DVCPRO HD Audio output to HD1400
    Posted by Mark Hatch on November 14, 2006 at 11:17 pm
    So, on one of my G5s, I can’t get the Audio Playback to work with firewire and the Panasonic HD1400 deck. It is playing back the video fine through the deck but can’t seem to output audio. (DVCPRO HD) At least 2 of my other computers are doing it, but not this one. Any ideas?
    My options for audio playback are:
    Default
    Built-in
    AJA Kona
    Firewire DV (Grayed Out)
    Firewire DV50 (Grayed Out)
    HDV (Grayed Out)
    Somehow it doesn’t seem to recognize DVCPRO HD.
    My setup:
    OS 10.4.4
    FCP 5.1.1
    KONA LH 3.2
    Panasonic HD1400
    **My other setups, which do work, are exactly the same.**
    Mark
    Jeremy Garchow replied 19 years, 9 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    November 15, 2006 at 3:18 am
    Make sure the deck is in 1394 mode, and then reselect an appropriate easy setup in fcp. Make sure you choose audio follows video.
    Jeremy
  • Mark Hatch
    November 15, 2006 at 5:27 pm
    Jeremy,
    I did the easy setup and it got me a little further. In the audio playback area (under the “View” menu), I now get “[Missing] DVCPRO HD Out” (Grayed Out). So it thinks it is missing. The deck shows that the 1394 Video input is locked and the 1394 audio input is locked, but fcp shows that only video output is working and the audio output is missing. Very odd. Any other ideas?
    Mark
  • Jeremy Garchow
    November 16, 2006 at 2:26 pm
    Audio playback should be set to ‘audio follows video’.
