Activity › Forums › Apple Final Cut Pro Legacy › no dissolve with HD
no dissolve with HD
Posted by Johan Moeskops on November 13, 2006 at 4:31 pmHi.
I am working on a DVCPro HD job.
In the beginning I have made serveral dissolves, now I can
Tom Wolsky replied 19 years, 10 months ago 3 Members · 5 Replies -
Walter Biscardi
November 13, 2006 at 4:43 pmMust be not enough or no tail on the outgoing clip or not enough or not lead on the incoming clip. That’s the only way transitions don’t work in FCP.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Walter Biscardi
November 13, 2006 at 7:52 pm[Johan Moeskops] “I have DVCPro HD 720P 50 footage.
I have only 720P25 in FCP, so I have to render all the clips.Will you give me the proper workflow please, for the video- and sequence settings.”
My guess would be to make a Sequence Preset and change the frame rate to 50, though I have not checked to see if you can do that. Havne’t worked with 720p/50 here so I honestly haven’t tried anything in that workflow. 1080i/50 yes, that’s what we’re doing right now, though the actual playback is 25fps so we’re using the AJA Kona 3 1080i/25 preset.
Johan Moeskops
November 14, 2006 at 1:48 pmHi Walter.
My Audio&Video setup is DVCPro HD 720p 50
My sequence settings are:
Framesize 960×720
Pixel aspect ratio HD 960×720
editting Timebase 59.94
QuickTime Video Settings DVCPro HD 720p 50Thanks in advance.
Regards, Johan
Tom Wolsky
November 14, 2006 at 2:06 pmhttps://www.aulich-adamski.de/en/perm/720p50-capturing-editing-in-final-cut-pro
The dissolve question, as Walter said, is probably related to not having enough handles for your media.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
