Activity › Forums › Panasonic Cameras › NO DECK NEEDED!
NO DECK NEEDED!
Posted by Sanjin Jukic on April 17, 2005 at 9:43 pmPanasonic P2 AG-HVX200 – P2 and DV tape recording, FireWire AVC and SBP2 (whatever that is)
P2 doles allow varicam style frame rates
NO DECK NEEDED!
Read at
Sanjin Jukic
S J Digital Productions
https://www.sanjinjukic.com
sanjinjukic@yahoo.com
Vienna
Austria
EuropeChristopher S. johnson replied 21 years, 5 months ago 6 Members · 9 Replies -
Sanjin Jukic
April 17, 2005 at 9:57 pmAlso:
“Panasonic AG-HVX 200
Support for P2
John Baisley, president Panasonic Broadcast & Television.
AG-HVX 200
DV DVCpro, DVCpro 50, DVCPRO HD
480i, 1080i, 1080p 24, 720p 60/24
Variable frame rates in 720p
3 chip 1/3″ 16:9 native CCDS
P2 Memory and DV tape recording
FireWire AVC and SBP2The P2 Memory allows varicam frame rates.
Camera that does SD and HD with no deck needed.Price $5995.
This will kill the rest of the industry
Available Q4 2005”Sanjin Jukic
Vienna
Austria
Europe -
Bob Hudson
April 17, 2005 at 10:53 pm[Sanjin Jukic] “SBP2 (whatever that is) “
I wonder if that should be USB-P2 and if it’s a way to transfer from P2 cards via USB???
Bob Hudson
Consultant & Writer
Video, DVD and
Multimedia Production
Overland Park, Kansas USA
https://www.bobhudson.com/ -
Sanjin Jukic
April 17, 2005 at 10:58 pmSteve Mullen is missing here to explain it.
Sanjin Jukic
Vienna
Austria
Europe -
Misha Aranyshev
April 17, 2005 at 11:24 pmSPB2 is the protocol FireWire storage device talks. AVC is the protocol FireWire cameras, decks and converters talk. So it is possible to download footage from inserted P2 to a computer via FW and it is possible to transfer footage from tape to a computer via FW. The big question is whether AVC support DVCPRO50 and HD or not to allow E-E recording in this format. Since there are DVCPRO50 and DVCPRO-HD decks with FW it is highly likely.
Jan Crittenden livingston
April 18, 2005 at 12:41 amMishka asked:
The big question is whether AVC support DVCPRO50 and HD or not to allow E-E recording in this format. Since there are DVCPRO50 and DVCPRO-HD decks with FW it is highly likely.The 1394 will allow for streaming video from the camera in n of the DVCPRO codecs or DV. No problem at all.
Hope that helps,
Jan
Jan Crittenden Livingston
Product Manager, DVCPRO, DVCPRO50, AG-DVX100
Panasonic Broadcast & TV Systems -
April 18, 2005 at 12:44 amWell this really is the elephant siting in the room. I wonder when we will find out about a portable live recording hard drive solution. Right now it looks like almost $4000 for 16 minutes of recording.
-Christopher
Paul Harb
April 18, 2005 at 12:47 amI assume you were trying to say “any” of the DVCPRO formats…so you could hook up a drive out in the field and record straight to it?
Paul
April 18, 2005 at 12:49 am[Christopher S. Johnson] “Well this really is the elephant siting in the room. I wonder when we will find out about a portable live recording hard drive solution. Right now it looks like almost $4000 for 16 minutes of recording. “
Actually Chris if you were to record in 24P on the P2 card in 720P you could get close to 20 minutes per card on an 8 GB card. These will be available about the same time as this camera. We are a partner with Focus Enhancements so those of you that want a live 1394 to hard drive solution, my feeling that too will be possible about the same time.
Hope that helps,
Jan
April 18, 2005 at 12:54 amYes Jan, that is indeed helpful. You often are 🙂
Did everybody read the post from Jan clearly?
-Christopher Johnson
