Activity Forums Apple Final Cut Pro Legacy No Deck Communication
  • No Deck Communication
    Posted by Andrew Hampy on October 9, 2007 at 6:43 pm
    I am trying to get signal to an external monitor (Sony Broadcast monitor)through a Panasonic AGDV2500 deck via the y/c in on the monitor and y/c or s-video out of the deck. The deck is hooked up via FireWire to my G4 running FCP 5.1.4 . It seems that this is a settings issue in FCP. I can get signal from the deck to the monitor playing a tape. I can also get signal when I do “Print To Video” in FCP. However I can’t get signal when I scrubbing in a time line or playing clips the browser window. I have the Audio Video Settings set to “FireWire NTSC” in the Device Control drop down and I have Video playback also set to “Apple FireWire NTSC. I have closed out of FCP turned off the deck with no luck. Since it works when I hit “Print To Video” seems like some setting is wrong. There is just not constant flow of signal through the deck from FCP. Any help is appreciated. Thanks
    Andrew
    Rob Forsythe replied 18 years, 11 months ago 2 Members · 1 Reply
  • Rob Forsythe
    October 9, 2007 at 7:10 pm
    This list contains virtually everything to try to enable:
    a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
    b. Viewing in the Canvas window on the computer screen.
    c. Being able to record on the external FW DV deck or camcorder.
    d. Being able to capture from a FW device.
    If working this list doesn’t cure the problem… you may have a serious PROBLEM!
    Try things in this order until you find the “cure”:
    1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
    2. Make sure you have View (Menu) > External Video> All Frames set.
    (If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
    3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen or “pushed into” other windows.
    4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
    5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
    6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
    7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
    8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
    9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
    10. Make sure you have chosen FW output for A/V:
    Final Cut Pro (menu) > Audio/Video Settings… >
    Video Playback: Apple FireWire NTSC (720 x480)
    Audio Playback: FireWire DV
    11. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
    12. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
    13. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
    14. Re-check that your FW cable is well-connected at both ends (or try a new cable).
    15. Important: Quit FCP, then Restart FCP.
    16. Now again, make sure you have View > External Video > ALL FRAMES set…
    If it still does not work. “Trash” the FCP Preferences on the Mac
    “FCP Rescue” is a free Apple Script that will Trash the Preferences.
    It will also restore your user settings afterwards.
    Download:
    https://www.macupdate.com/info.php/id/14729
    If you have “lost” your entire FW connection between the Mac and the device, go HERE:
    https://docs.info.apple.com/article.html?artnum=301852
    >Then, start again at my “step 1” above.
