Activity Forums Apple Final Cut Pro Legacy No Compressor
  • Posted by James Bishop on April 5, 2010 at 1:56 pm
    Please help!! I have final cut pro 5, but my compressor does not work. I have been told that the only way to fix it is to re-install, but I don’t have the original disks.
    I have edited a film which is about an hour in length and too big to fit on a 4.7 DVD.
    Are there any other programs out there similar to compressor that I could use to shrink this file for DVD?
    Brad Elliott replied 16 years, 5 months ago 3 Members · 2 Replies
  • Walter Biscardi
    April 5, 2010 at 2:07 pm
    Telestream Episode
    Innbits BitVice
    Sorenson Squeeze
    and a host of other compression utilities, but these are the most popular and some of the best out there.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” featuring Sigourney Weaver coming soon.
    Blog Twitter Facebook
  • Brad Elliott
    April 5, 2010 at 2:16 pm
    If you have DVD Studio Pro you could compress a movie from FC in DSP.
    If you don’t have over 75 minutes a varible bit rate with an average of 6.3 and a peak of 7.5 will work. You could also do a CBR at 7. Opinions vary on which is the better option. I have had success with the variable option. You will need to create an AC3 as DSP will give you an aiff.
    If your footage is longer than 75 minutes I would Google a bit rate calculator.
    The compressor in DSP isn’t the best option but for SD video it will deliver decent results.
