Activity Forums Apple Final Cut Pro Legacy No Communication after I click on Mastering Settings
  • No Communication after I click on Mastering Settings
    Posted by Phil Yunker on May 22, 2008 at 9:55 pm
    Hello,
    We are using a Panasonic AJ-HD3700B (HD D5 deck) and a Sony DVW-A500(DigiBeta) for mastering. When I click on the Mastering Setting tab in the edit to tape window click on or off what I need then go back to the video tab to record I loose communication with the deck. The only way to regain communication is to power off the computer, restart then open FCP. However, when I open up FCP I and try to master the settings in the Mastering Settings may or not be set, thus, I have to set everything then power off…and the whole cycle of madness begins or continues.
    Kona Card 3
    FCP 6.0.3
    Thanks for any help!
    PHIL
    Phil Yunker replied 18 years, 3 months ago 2 Members · 4 Replies
  • Richard Sanchez
    May 22, 2008 at 11:44 pm
    I’ve found the Mastering mode to be particularly troublesome with the HD3700B, so I layoff using the editing mode. I believe the only difference is you’ll have to lay in your color bars and the set the reference tone manually, and if you want black to proceed your program, you’ll have to cut in a slug manually also, but that’s how I layoff with that deck.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Phil Yunker
    May 23, 2008 at 1:02 am
    Richard,
    Thanks for the reply.
    However, this does not explain the exact same problem with the Sony DigiBeta deck. Must be a FCP thing?
    Anyone?
    Phil
  • Richard Sanchez
    May 23, 2008 at 3:27 am
    That’s weird. I use the DVW-M2000 for Digibeta, and it seems to work both ways, but I still use the editing mode for lay offs, as I do a lot of insert editing. I don’t have the answer regarding why it’s happening. At one point, I couldn’t get the HD deck to recognize deck control at all and after i trashed my settings, it worked fine, so that might be one avenue to check out.
    Richard Sanchez
    North Hollywood, CA
  • Phil Yunker
    May 23, 2008 at 11:25 am
    I have trashed the pref’s and no luck. I use the Sony DVW-A500(DigiBeta) all day long on another system with no problems at all. must be a FCP issue.
