Activity Forums Apple Final Cut Pro Legacy No Communication !!
  • No Communication !!
    Posted by Timothy Barksdale on January 14, 2015 at 9:09 pm
    Folks,
    Before I had to leave town for a week, I have been working with Kona support on this and have not heard back from them today. I need to solve this ASAP, please.
    I am using an older MacPro-
    Mac OS version is OS X Lion 10.7.5 with 2×2.66 Ghz Dual Core Intel Xeon
    5 GB 667 MHz DDR2 FB-DIMM & NVidia GeoForce 7300 GT 256MB
    My Deck is the Sony J-H3, tried and true. Since bring it back from Austin, Texas, I’ve had some strange issues. But I think all cables and settings are correct with the deck.
    the HD-SDI goes into the Kona 3 breakout box and the RS-422 cable too from the remote port in the deck to the proper port on the box.
    there has been a very nice full color image of what ever is playing on the deck. And in the Log & Capture window… no time code and in the bottom center – NO COMMUNICATION.
    I have the Kona Control panel open and under the time code tab in the Input box. next to the RP188 LTC tab- I can see red or blue time code depending on whether the deck in playing or not.
    Ive trashed preferences and reset everything I can think of.. In audio/video settings I’ve played with Deck settings etc. But cannot figure out what is wrong. I know it must be a setting within FCP 7.0.3 because the time code is in the machine…. Right?
    Tim Barksdale
    Birdman Productions LLC
    Choteau, MT
    Shane Ross replied 11 years, 8 months ago 4 Members · 12 Replies
  • 12 Replies
  • Shane Ross
    January 14, 2015 at 9:57 pm
    Maybe try a different RS-422 cable? I had this issue at one point too, and a new cable did it.
    Shane
    Little Frog Post
  • Timothy Barksdale
    January 14, 2015 at 11:23 pm
    Yo Shane,
    Hope you are well. !
    The newest cable is doing the best job. I have 3 here now. After I installed it, the Time Code appeared in the AJA Control Panel. So we are making progress… slowly.
    My question is since the control panel sees the TC and the Log & Capture window are showing the video, then.. ? Why no communication?
    Tim Barksdale
    Choteau, MT
  • Shane Ross
    January 15, 2015 at 12:05 am
    Signal is one thing, communication is another. The video signal is fine, so your SDI connection is solid. The connection is deck communication, and that is specifically the RS-422 connection.
    Shane
    Little Frog Post
  • Timothy Barksdale
    January 15, 2015 at 12:57 am
    Buying two new cables…. can’t afford to have this happen again…
    Tim
    Tim Barksdale
    Choteau, MT
  • Shane Ross
    January 15, 2015 at 1:11 am
    Wondering if it might not be something on the end of the deck, or the AJA Box. YOu did say the deck was acting up.
    Shane
    Little Frog Post
  • Timothy Barksdale
    January 15, 2015 at 3:46 am
    Shane,
    I went through about 7 hours of looking at every software option, clearing Pram etc. After another hour with Steve of Aja Support, we can only conclude that it tis the cable. I’ve bought 2 new ones with new 422/232 adapters. If this does not work, then I’m back to square one. I’ll keep this forum posted on the progress.
    Thanks for you concern,
    TRB
    Tim Barksdale
    Choteau, MT
  • Shane Ross
    January 15, 2015 at 4:27 am
    Yeah…whenever I had this issue it was always the cable. Brittle things.
    Anything for a fellow Montanan!
    Shane
    Little Frog Post
  • John Christie
    January 15, 2015 at 9:04 pm
    Just curious why you would use a RS232 adapter. The JH3 has a 422 port doesn’t it? (Been a while since I worked with one)
    Also, not all 422 cables have all the pins active. You might want to check the pinouts with a continuity meter.
    From the interweb:
    Sony 422 Machine Control Pinout
    The connectors are 9-pin D (D9).
    The cable is always male on both ends (D9-M).
    D9C-M is male crimp and D9S-M is male solder.
    Store-bought cables are usually wired straight through, pin for pin with all
    the pins connected, but there are only four pins that must
    go through for the cable to work; 2, 3, 7, and 8.
    These are the pin names that Sony uses on its play machines.
    1. Frame Ground
    2. Transmit A
    3. Receive B
    4. Receive Common
    5. Spare
    6. Transmit Common
    7. Transmit B
    8. Receive A
    9. Frame Ground
  • Timothy Barksdale
    January 15, 2015 at 11:05 pm
    Hi John,
    Thank you for your detailed response.
    The J-H3 does have a remote input with 9 pin above a
    RS232c connector at the bottom lower right as you face the rear of the deck.
    I’ve had suggestions from LTC/VITC and having gone through every software panel option, I think we are left with the cable being the final option .
    If this does not work… I will let everyone else know…
    Tim Barksdale
    Choteau, MT
  • Tom Matthies
    January 16, 2015 at 7:11 pm
    That deck DOES have an RS-422 jack. It’s the one labeled “Remote” right above the RS-232 port. Use this connector with the Kona card and not the RS-232 port. It should be pretty much plug and play unless the menu settings on the deck were changed.
    Not my monkeys. Not my circus.
