Activity › Forums › Apple Final Cut Pro Legacy › No codec in FCP7 for dvcpro HD?
Posted by Philip Moran on October 17, 2011 at 11:39 amI have some .avi files recorded direct to hard-drive from a Panasonic camera (don’t remember model, but records to tape, format dvcpro HD) using Abobe Onlocation.
I can’t import these to final cut and the video doesn’t play using quicktime – audio works though.
Am sure it’s a codec issue, but can’t find a download that works anywhere and all the forums seem to say that the codec should already be installed with final cut anyway.
Would appreciate any help.Mac Pro 2 x 3GHz Quad-Core Intel Xeon
OS X 10.6.8Cheers, Phil M
Philip Moran replied 14 years, 11 months ago 4 Members · 9 Replies -
Ryan Holmes
October 17, 2011 at 4:35 pmAVI is just a wrapper, like Quicktime. FCP can ingest AVI files, but their playability depends on what codec was used inside of the wrapper. If you don’t have the correct video codec the picture won’t show. If you hear the audio then your system has the correct audio codec.
You’ll need to download the video codec associated with the camera you shot and you should be good to go.
Ryan
Rafael Amador
October 17, 2011 at 5:14 pmRyan is right, but is supposed that if you have FCP you have the DVCProHD codec.
That may be an issue of the AVI envelope.
Make a test.
Rewrap an AVI as QT.
Open the file in MPGStreamclip and “Save as: QT”.
rafael -
Ryan Holmes
October 17, 2011 at 9:29 pmAgreed. You should have DVCPRO HD codecs if you have the FCP Studio. However, I’ve seen stranger things happen. You can easily check what codecs are installed just open a Finder window and go to your:
BootDrive/Library/QuicktimeIn there you should 5 or 6 different DVCPROHD components. 1 of them should say DVCPROHDCodec.component
Ryan
Ryan
http://www.studio006.com
“Some men are born mediocre, some men achieve mediocrity, and some men have mediocrity thrust upon them.” -
Shane Ross
October 17, 2011 at 10:01 pmThere is a big difference between the DVCPRO HD codec in FCP and the one from Adobe. They are not the same codec. You recorded with the ADOBE DVCPRO HD codec…not the FCP one. That is why you are having issues. You will need to convert this to a format FCP works with…from AVI to MOV…and on a machine that has Adobe CS and FCP, so that you have access to all the codecs.
Shane
Read my blog, Little Frog in High Def -
Philip Moran
October 18, 2011 at 4:48 amThanks Raphael. I tried this and had no joy. I have also checked that the .component file was present as in ryan’s post. Am at a loss!
Philip Moran
October 18, 2011 at 4:55 amThanks Ryan. I checked and I do have the codec. Also Raphael wrapper suggestion hasn’t worked either. Very odd.
Philip Moran
October 18, 2011 at 4:58 amThanks Shane – looks like that must be my problem. Thanks for the help. Phil
Rafael Amador
October 18, 2011 at 3:46 pmHi Phil,
Shane has a lot of experience with DVCproHD stuff.
I would stick to his advice.
rafael -
Philip Moran
October 19, 2011 at 7:29 amHi Shane – you were spot on. I downloaded the trail version of CS5.5 from Adobe and was able to open the files and convert them to quicktime. All is good. Thanks for the help. Phil
