Activity › Forums › Adobe After Effects › No Change when Adjusting Z Position
  • No Change when Adjusting Z Position
    Posted by Randy Rubin on February 5, 2013 at 8:57 pm
    Hi All,
    I’m trying to do a very simple animation of a layer with a thick line from illustrator. I want to adjust the Z position so that it looks like the line is landing on the composition from above.
    I’ve done this effect in previous projects without issue but for whatever reason when I adjust the Z position nothing happens. All layers have 3D turned on. There are some pre-comps as well, but everything has the 3D enabled.
    Any help appreciated.
    Randy Rubin replied 13 years, 7 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    February 5, 2013 at 9:13 pm
    Are you by chance looking at the preview through the Front View and not the Active Camera
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Randy Rubin
    February 5, 2013 at 9:28 pm
    Yep lol. I knew it was some simple mistake. Thanks.
