Activity Forums Apple Final Cut Pro Legacy No Capture Window
  • No Capture Window
    Posted by Steve Wargo on February 19, 2007 at 10:15 pm
    We open the capture window and it does not appear. Any ideas?
    I had the BMD Deck Capture Window open, but closed it and now the FCP cxapture window is gone.
    We have rebooted several times
    Steve Wargo
    Dual 3.0 MacPro
    BMD Decklink HD card
    Internal 2.1Tb Raid
    &Tb X-Serve Raid
    Steve Wargo replied 19 years, 7 months ago 3 Members · 2 Replies
  • Bouncing Account needs new email address
    February 19, 2007 at 10:29 pm
    First, go to the Window (pull-down menu)> Arrange and try “Restore Window Layout…” (or some of the other choices).
    If that doesn’t work…
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    or
    https://pistolerapost2.com/fcprescue/
    This is one FCP tip that has helped in solving hundreds of “odd” problems.
  • Steve Wargo
    February 20, 2007 at 10:32 am
    That did it.
    Thanks again
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
