Activity › Forums › AJA Video Systems › No Capture Via Kona LH
  • No Capture Via Kona LH
    Posted by Robert Ober on February 5, 2006 at 3:53 pm
    Hello Kona Folk,
    I updated to the 1.2 driver after doing an unistall of the 1.1.6. I now cannot capture via the analog component in from either a HD source or a SD source. No conflicts according to the checker. Kona TV works so the card is recognized and it appears in system info.
    I did add a Highpoint 2220 SATA controller to the PCIX slot since my last capture so I will pull that and disable it’s driver. However, it is not likely the SATA card is the issue.
    Yes, I did delete the prefs for all Kona and am using VTR Xchange so FCP is not a factor. I also reseated the card.
    Ideas?
    Y’all have a fun sun., football or not.
    Robert
    Robert Ober replied 20 years, 7 months ago 1 Member · 1 Reply
  • Robert Ober
    February 17, 2006 at 5:00 am
    This was the procamp issue that Kona have acknowledged. It is working now with the 1.2 driver.
    Robert A. Ober
