Activity › Forums › Adobe Premiere Pro › No capture of stereo-recorded audio
  • No capture of stereo-recorded audio
    Posted by Eminentmike on November 25, 2006 at 5:56 pm
    I shot some footage and, apparently, recorded the audio in stereo.
    Batch capturing the logged fails because the source audio is stereo and the project only want to recognize a single track.
    I have adjusted some project settings as a test and was able to direct capture one clip, but the audio seems to be lost even though it shows up in the timeline.
    What am I doing wrong?!
    A learner’s THANKS in advance.
    Multimedia is the educator’s best friend.
    Mike Velte replied 19 years, 10 months ago 3 Members · 2 Replies
  • Tcindie
    November 25, 2006 at 7:09 pm
    It sounds like you’ve got your project set up for mono sound. You should be able to change that in the project settings, but if you can’t, why not start a new project with the audio set to stereo, and capture in it?
  • Mike Velte
    November 26, 2006 at 12:18 pm
    What kind of camcorder records mono audio? Did you set your camera to record to channels 3 and 4 at 12 bit?
