No Blu-ray files working in Architect
Posted by Gary Abraham on June 30, 2011 at 12:06 pmPlease Help.
All files I make for Blu-ray are not recognized in Architect.
AVC files or Mpeg2 files when draged to Architect show thw following message.
“Information unavailable. Media must be prepared to open”
I was able to make Blu-rays before with no problem.
I am using Vegas 10
GaryJohn Rofrano replied 15 years ago 3 Members · 8 Replies -
John Rofrano
June 30, 2011 at 6:22 pm[Gary Abraham] “I was able to make Blu-rays before with no problem.”
What changed about your computer? What new software did you install? Do you have a restore point that you can go back to?
What template are you using in Vegas Pro 10?
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Mark Krueger
September 17, 2011 at 6:57 pmI am having the same problems with the no information message… any help. I have not installed anything new other than a hard drive.
John Rofrano
September 17, 2011 at 10:45 pm[Mark Krueger] “I am having the same problems with the no information message… any help. I have not installed anything new other than a hard drive.”
What template are you using to render to Blu-ray?
~jr
Mark Krueger
September 18, 2011 at 10:45 amThe template I used for Sony AVC was: Blue Ray 1920×1080-60i-16mbs video stream.
I also rendered it as Main Concept AVC/AAC(.MP4) DEFAULT TEMPLATE and it imported it into Architect just fine. Do you know if that is a lower quality?
I think someone or you said that Sony AVC was the best, so I would like to get it working again.
John Rofrano
September 18, 2011 at 4:34 pmYou’re using the correct template. Something else must be wrong. Do you have any codec-paks installed like K-lite? Codec-paks can mess up your PC.
~jr
Mark Krueger
September 18, 2011 at 8:39 pmI am using Raylight Ultra to import Panasonic MX files… Have you heard of any problems here
John Rofrano
September 18, 2011 at 11:58 pm[Mark Krueger] “I am using Raylight Ultra to import Panasonic MX files… Have you heard of any problems here”
No problems. So you are importing MXF files into Vegas and rendering as MPEG2 Blu-ray and DVD Architect won’t recognize them? That should work.
~jr
