Activity Forums Compression Techniques No batch cropping with Squeeze 5.1?
  • No batch cropping with Squeeze 5.1?
    Posted by Jeff Handy on July 24, 2009 at 1:27 pm
    When applying a cropping parameters to a setting and subsequently processing a batch with it applied, our clips do not get cropped. We are processing hundreds of files and can’t afford to crop each clip manually. This worked fine in 4.5, but not so with 5.1. I tried a completely fresh installation after deleting all references to sorenson and squeeze – still no cropping gets applied.
    Is there some kind of trick to get it working?
    Computer – Mac
    Operating system – 10.4.6
    Software – Squeeze 5.1.1
    Source codec – DVCPro50 and H.264
    Destination codec – FLV (Flash 8 compatible)
    Type of destination use – Learning Management System (web)
    Jeff Handy replied 17 years, 1 month ago 1 Member · 1 Reply
