Activity › Forums › Apple Motion › no background
no background
Posted by Marcel Tiemensma on January 27, 2007 at 12:24 pmI want to animate a type effect in Motion and then export to AVID. But I only need the letters and not the background in AVID. In other words:
the letters should lay over the video. I tried different things without success. What should I do?
Thanks!Paul Coull replied 19 years, 8 months ago 3 Members · 6 Replies -
Walter Biscardi
January 27, 2007 at 1:03 pmThat’s called an Alpha Channel. Export using Lossless+Alpha
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Marcel Tiemensma
January 27, 2007 at 8:07 pmWhere do I find that….? It’s not in the export-settings….?
Marcel Tiemensma
January 27, 2007 at 10:01 pmIn other words: I just wanna add an alpha channel so that AVID can read it….searched for it, couldn’t find it….
Marcel Tiemensma
January 28, 2007 at 8:52 amI’m on motion 1 and the last hours i tried again everything. For ex: I put the background color (in property setting) on 0 %. I found the export setting lossless movie + tried exporting alpha and/or color and alpha.
In motion I get the checkerboardbackground (which means transparancy I guess)….but all I see in AVID is a background and the text doesn’t lie over the AVID-background. I’m desperate. It shouldn’s be so difficult to export ONLY text, in my opinion. But where’s the secret button????? -
Marcel Tiemensma
January 28, 2007 at 2:52 pmThat’s funny…I’m so lonesome I reply to myself the whole time…there’s no motionboard I guess…
Anyway, I found out how it works….so no need to reply anymore (probably needless to say….) -
Paul Coull
January 29, 2007 at 9:54 pmHi
Try changing the codec settings to animation millions plus. The plus will be your alpha.
I’m not sure how avid will cope with this codec and the alpha!Hope this helps.
grafx that flow!
