Activity › Forums › Maxon Cinema 4D › No Background in Model
  • No Background in Model
    Posted by Richiehatch on February 28, 2007 at 2:02 am
    Hi
    I am rendering a model of a bridge part of which has a mesh surface which you can see through (with an alpha channel. The model when rendered will be photomontaged within Photoshop. Perhaps its simple but I cant find it, but can ye render the model so that it has no colour in the background…? So just a transparent background PSD file that ye can stick an image behind in PS and that would appear behind the mesh..? Sorry if i am not explaining myself correctly… Its 2am here…!
    Richie
    Mylenium replied 19 years, 7 months ago 2 Members · 1 Reply
  • Mylenium
    February 28, 2007 at 7:05 am
    No. The RGB buffer will always have a background color, but since you get an Alpha channel, I don’t see a problem. It’s as simple as selecting the Alpha, making the background layer a floating layer and applying the selection as a mask. The only thing to take care of is to use straight Alpha. Photoshop does not handle premultiplied Alpha correctly.
    Mylenium
    [Pour Myl
