Activity Forums Adobe After Effects no auto trace?
  • no auto trace?
    Posted by Zander on April 21, 2006 at 3:09 am
    ok, so i just got finished attempting (multiple times) aharon rabinowitz’s super tight junkmatt tut. and found i have this problem, with all my settings identice, i can’t seem to get the autotrace new layer to create something in the timeline, or make a visible mask, im very very confused by it all
    what i have is the autotrace layer created, but it’s as if there’s no media there, im not sure what to do?
    thanks
    Aaron Zander-Student edditor
    If it’s out there and it does somethign to something,
    teach me how to use it
    Powerbook g4 1.5 GHz (it might not be big, but i can take it on set
    fcp 5, ae 6.5pro adobe cs2
    Aharon Rabinowitz replied 20 years, 4 months ago 3 Members · 6 Replies
  • Justin Productions
    April 21, 2006 at 3:35 am
    Auto-Trace traces a mask around a keyed footage (with transparency; alpha). You could send a screenshot of your comp and monitor window here, that would help.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.0 Professional
  • Zander
    April 21, 2006 at 6:25 am
    ok heres the shot keyed, with the auto trace dialogue
    https://img.photobucket.com/albums/v433/amz370/screansettings.jpg
    heres it with auto trace done
    https://img.photobucket.com/albums/v433/amz370/timeline.jpg
    and a close up of the timeline, any additional shots can be added
    https://img.photobucket.com/albums/v433/amz370/aftertrace.jpg
    April 21, 2006 at 8:24 pm
    You need to apply the auto-trace to your keyed footage, and not on a Layer. By the way, it’s not geenscean but green screen.
    In you timeline, just to the left of your layer, you’ll see a little triangle. Untwirl it, you’ll see “Mask”…untwirl that too and there you go.
    Does that respond to your question?
    Auto-trace is simply used to create an outline around a keyed layer. For example, you could apply Render > Stroke to it and make the mask a stroke (in the effect window) around your keyed auto-traced footage, etc.
    Justin Productions
  • Zander
    April 22, 2006 at 2:46 am
    well yes, now i get the trace and thanbk you BUT, im following along in Aharon’s demo, and he has a second layer, a solid created by the autotrace, i can’t achieve this, im so confused
    for referance on aharon’s footage check the tuturials (the non ipod version should be posted tonight, as they are a week behind
    and yes, i know, i didn’t title the footage, silly directors, what do they know right?
    thanks again
  • Zander
    April 22, 2006 at 5:20 am
    ok, so heres a compare image
    the top is aharons file with the auto trace, the bottom is mine (with fixed spelling!), ive done everything identicly, i can’t figure out whats up here?
    https://img.photobucket.com/albums/v433/amz370/compare.jpg
  • Aharon Rabinowitz
    May 8, 2006 at 10:43 pm
    one of the options is to create a new solid with the masks called “Apply to New Layer” if you don’t have that option selected it will just creat the mask on the original layer.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
