Activity Forums Blackmagic Design No Audio while previewing a tape
  • No Audio while previewing a tape
    Posted by Srfval on February 14, 2006 at 12:55 pm
    Using Extreme in SD format I am capturing in Premiere Pro 1.5 from a Sony J-3 deck via SDI input for Video & Balanced XLR for Audio. The result is an AVI file with great picture quality and stereo audio.
    My problem is that while i am previewing my tape (before i even press the capture button) i have NO sound at all. That is a major problem cause i cannot find the exact points i want to capture.
    I have tried all the possible combinations in Premiere & the Deck Control i knew, but no result. The SPDIF & XLR audio outputs the Extreme has, has nothing to do with the preview during playback.Right?
    I am almost 99% sure that there is something in the software settings but i cannot find what.
    Please tell me if there is another way to accomplice that.
    Thanx In Advance
    Srfval replied 20 years, 7 months ago 2 Members · 2 Replies
  • Kristian Lam
    February 16, 2006 at 5:22 am
    Can you check the DeckLink control panel and ensure that “Black Video Output to Deck in Capture” is disabled?
    regards
    Kristian
    Blackmagic Design
  • Srfval
    February 16, 2006 at 8:09 am
    Hi Kristian and thanx for ur answer.
    I did that and is working. BUT, correct me if i am doing something wrong here, i took the 2 XLR audio output of Decklink and send them to the Line IN of my pc so i could preview through my PC Speakers.
    The problem is that i listen to audio but with a lot of noise (HISSS).
    Am i doing something wrong? What is the correct connection for listening from PC Speakers?
    Thanx.
