Activity Forums Apple Final Cut Pro Legacy No audio while capturing
  • No audio while capturing
    Posted by Salilsundresh on July 24, 2005 at 6:10 am
    For some reason when I am capturing dv in Final Cut Pro 4, there is no audio. However, it is capturing it because I checked the clip settings and it says it is capturing audio + video. Also, when I play the video back after capturing, there is audio, just not when capturing. Please help, I am a former premiere pro user and have gone through a lot of pain to get a mac that works. (right now many of the new powermac g5s have a fan problem)
    Incase this information helps, here are my specs:
    Powermac G5 dual 1.8ghz
    1.25gb ram
    OS X 10.3.9
    Boot ROM Version: 5.1.8f7
    GeForce FX 5200:
    Type: display
    Bus: AGP
    Slot: SLOT-1
    VRAM (Total): 64 MB
    Vendor: nVIDIA (0x10de)
    Device ID: 0x0321
    Revision ID: 0x00a2
    ROM Revision: 2060
    Display:
    Type: display
    Display Type: CRT
    VRAM (In Use): 64 MB
    Resolution: 1280 x 960 @ 75 Hz
    Depth: 32-bit Color
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Salilsundresh replied 21 years, 2 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    July 24, 2005 at 6:36 am
    Duplicate the DV capture preset you are using now. In the Preset editor window that will open when you duplicate, click on the advanced button in the audio area of the window. Turn speakers to ON in the pop up menu there… use this capture preset to have your computer’s speakers monitor audio when loging and capturing…
    Jerry
  • David Roth weiss
    July 24, 2005 at 10:20 am
    [salils] “(right now many of the new powermac g5s have a fan problem)”
    Can you please ellaborate on this… I have a brand new G5 and I’d kind of like to look into this if you could tell me what I’m supposed to look at.
    TIA,
    DRW
  • Salilsundresh
    July 25, 2005 at 1:18 am
    Here’s one of the sources, search the apple forums for more: https://discussions.info.apple.com/webx?13@218.0hY0aXDjWs7.1@.68b1ebca/14
    Here’s my story:
    When I first booted-up, everything was fine. But then later on I booted up again and it sounded like a jet engine! Lots of people are having this problem and it is because apple made a change in the hardware, so most of the G5’s out there sound like air-conditionings right now and/or are freezing. I later found out that this was because there was a bad batch made in dec ’04. The problem seems to ly in a change in the SMU on the logic board to make production of power macs cheaper. However, a few of them do work, and others start having the problem right out of the box. Some other people have had this problem occur after a few months of purchase, so it can really occur at anytime.
