Activity › Forums › Avid Media Composer › No audio when trimming B side only
  • No audio when trimming B side only
    Posted by Alex French on August 3, 2016 at 2:47 pm
    I am sure this is likely an easy fix, but I have no idea what I did and was not able to find the answer online.
    I’m suddenly not able to get any audio when trimming the B side only. Dual roller and A side work fine. I can scrub, I can get playback, everything is normal. I was briefly working in multicam mode, in case that might have something to do with it (which I doubt, but you never know).
    It seems to be just this project, because when I open a different project on the same computer, everything is working fine.
    Any help or suggestions would be great. I am at a loss, here.
    Alex French replied 10 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
