Activity › Forums › Adobe Premiere Pro › no audio waves
Ted Strickler
February 9, 2009 at 10:57 pmThis problem has been solved! So for those of you who might have this problem, definately check in ALL your set up menus and be sure the “Generate PEK files” is checked. Once I found that and checked it all my waveforms came back. I don’t know why that mp3 waveform showed up when .wavs would not but now I don’t care.
Thank you all,
Ted
Steve Brame
February 10, 2009 at 7:11 pmI have also noticed that if you edit audio from a clip or sequence in Audition or Soundbooth, the PEK file that those apps generate will not be read in Premiere. Delete those and Premiere will create it’s own and your waveforms will reappear.
Steve Brame
creative illusions Productions
VODSouth -
Allan Bagnall
July 1, 2009 at 11:45 pmWould you please set out the path to check the “Generate .PEK files”
AsI cannot find the box to check. Thank you Allan
