Activity Forums VEGAS Pro No Audio Sony Vegas Pro 9
  • No Audio Sony Vegas Pro 9
    Posted by Gary Badgley on August 23, 2011 at 1:56 am
    Hi, I coverted some AVCHD files using Neo Scene. I actually read the manual and installed the utility for audio playback. That helped as when I play back using WMP I have audio. When I playback in Vegas I have the Video in the preview window and on the trackline it appears that there is audio. But audio is, of course, not playing.
    Gary Badgley replied 15 years ago 1 Member · 2 Replies
  • Gary Badgley
    August 23, 2011 at 3:18 am
    Okay, to be a bit more precise, I am getting audio when I play the clips in the trimmer window. When I play the clips back using the timeline showing the video in the preview window I get no audio readings in the Master audio meter. The audio is showing below the video on the timeline.
  • Gary Badgley
    August 23, 2011 at 8:43 am
    Okay, that was a rough one. It turns out the mute button was turned on under the Options tab even though it was turned off on the mixer and track header. Editing AVCHD files on a 1.8 ghz processor is a tad difficult! So, I converted using Neo Scene and installed the audio utility as per the installation manual. The .avi files run smoothly now, with very little stutter. Superlative images. Thankyou Panasonic for this wonderful camera the AF100.
