Activity Forums VEGAS Pro No audio Plugins in Vegas11
  • No audio Plugins in Vegas11
    Posted by Don Hutcheson on June 6, 2012 at 4:54 pm
    I have been using Vegas since version 8, and it always had equalization, compression, etc, in the audio trac effects. Vegas 11 only has pan and volume. Where are the others? I am running the 64-bit version on a new 64-bit Windows computer with Windows 7. Specs are fine. When I select “Open in audio editor” as an alternative, it just sounds metalic in Adobe Audition. I could do all these things in Vegas 8 and 9.
    It also gives me an error message when I want to render to Main Concept AVC/AAC.mp4. It starts the render, then says it can’t continue and”no reason it found”.
    Don
    Hutch
    John Rofrano replied 14 years, 3 months ago 2 Members · 1 Reply
  • John Rofrano
    June 6, 2012 at 6:37 pm
    [Don Hutcheson] “I have been using Vegas since version 8, and it always had equalization, compression, etc, in the audio trac effects. Vegas 11 only has pan and volume. Where are the others?”
    It sounds like something is seriously wrong with your Vegas installation. The same audio plug-ins are available in 11 that were in 10, 9, 8, 7, 6, 5, 4, 3 (sorry i don’t have a copy older than Vegas Video 3) In other words, nothing has changed. I would uninstall and re-install Vegas and see if your plug-ins return.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
