Activity Forums Apple Final Cut Pro Legacy NO Audio playback in Viewer
  • NO Audio playback in Viewer
    Posted by Jdeditor on August 31, 2005 at 5:40 pm
    I get no audio after importing a .aiff file. It is 48k 16 bit Stereo.
    All of my other audio that was captured through my DVCPro 50 deck plays back fine.
    It is a speech that was captured as a QuickTime aiff.
    I should mention that it plays fine when cut into a time line. But it’s a long speech and I need to edit it. I can not hear it when it’s in the viewer.
    I’m on a G5 Dual 2.5 with FCP 4.5. Can anyone help?
    JD
    Post Response
    Jdeditor replied 21 years ago 2 Members · 5 Replies
  • Bouncing Account needs new email address
    August 31, 2005 at 6:04 pm
    First thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
    Next:
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCPro & FCExpress.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    ___________________________________________
  • Jdeditor
    August 31, 2005 at 6:56 pm
    Sorry I forgot to mention the obvious. I have done that and still NO AUDIO.
    And I use FCP Rescue. a handy tool.
  • Jdeditor
    August 31, 2005 at 7:06 pm
    UPDATE
    Our Project is DVCPro 50. We have a AJ-SD93 connected to our system via Firewire.
    When I switch the Playback Output (Under Audi/Video Settings) from Apple Firewire DVCPro50 NTSC (720×480) to Apple Firewire NTSC (720×480), the audio plays fine in the Viewer but picture is pixelated because it is a DVCPro deck.
    Can anyone explain this?
    thanks,
    jd
    August 31, 2005 at 8:01 pm
    Just a thought.
    The Final Cut Pro (menu) > “Easy Setup” should have been set to “DV50-NTSC” before you captured.
    This should be done first thing as you start a new project.
    Then the timeline and capture should match.
    If you DID this, I’m stumped.
  • Jdeditor
    August 31, 2005 at 8:50 pm
    I did do this. I’m stumped too.
    jd
