Activity Forums Adobe Premiere Pro No Audio playback in Monitor Window – Premiere Pro CC2020
  • No Audio playback in Monitor Window – Premiere Pro CC2020
    Posted by Abbas Agha on June 6, 2021 at 3:24 pm
    When I look at a clip in the source monitor, no audio can be heard. Even when I drag the clip from the sequence and play it, No audio or Bars. When dragging o. What is wrong?
    Bill Celnick replied 5 years ago 3 Members · 2 Replies
  • Eric Santiago
    June 8, 2021 at 1:41 pm
    Do you mean a regular display monitor?
    Is the audio present on the desktop or any other software?
    Can you see audio meters during playback?
    Maybe reset the Preferences.
    Have you ever heard the audio on that system using video/audio clips?
  • Bill Celnick
    June 8, 2021 at 2:01 pm
    whenever I’ve had similar issues, it was usually something simple, like I had the wrong output device selected in preferences, so, as Eric suggested, check there first…otherwise make sure you haven’t muted the track unintentionally.
    Can you hear the audio through your headphone out?
