Activity › Forums › Apple Final Cut Pro › No audio playback
No audio playback
Posted by Marc Lucas on February 7, 2012 at 11:39 pmI can skim clips in the clip browser and the audio plays but when I connect to the storyboard (timeline) the audio is connect to the clip and I can see the audio monitor moving but no sound is coming out? Hope I’m not going insane
Marc Lucas replied 14 years, 7 months ago 3 Members · 5 Replies -
Jeremy Garchow
February 8, 2012 at 12:40 am[Marc Lucas] ” Hope I’m not going insane”
Me too.
Try Quitting FCPX, trash your prefs, and restart your machine.
Richard Mccaslin
February 8, 2012 at 7:36 amyou might need to set the pan mode
click the clip on the timeline and open the inspector, and click on the audio tab
you may need to set the pan mode to stereo -
Marc Lucas
February 8, 2012 at 9:44 pmThe audio clip attached to the clip is mono its footage from an iPhone that I’m using to test somethings. I can scrub the audio in the clip browser and even in the audio inspector! But not in the timeline.
Richard Mccaslin
February 8, 2012 at 9:52 pmmake sure your project is in stereo
file > project properties
and then click the wrench in the inspector -
Marc Lucas
February 8, 2012 at 10:01 pmIt wasn’t it was in Surround for some reason but I’m not sure whether that was the actual problem. The Mono audio channel is set to mono and won’t work in the timeline when when set to Center, why not?
Least I’m getting sound out now will have an in-depth play with these settings.
