Activity Forums Adobe After Effects No Audio Output
  • No Audio Output
    Posted by Jake Stevens on August 28, 2016 at 2:09 am
    When I render audio or preview audio no audio is output.
    The audio speaker is active on the the layer but yet no audio!
    I have A.E. 2015.3cc v13.8.0.144
    iMac 27\”, i7, 4.0GHZ, 5K Retina, 32GB Ram, 512 SDD, 4TB Ext. HD, Final Cut Pro 10.2.3, After Effects CC v13.8.0.144 (2015.3 release)
    Walter Soyka replied 10 years ago 2 Members · 1 Reply
  • Walter Soyka
    August 28, 2016 at 4:22 pm
    Is the correct device set in Preferences > Audio Output?
    If you select the layer with audio and hit LL to reveal the waveform, do you see anything? Is it perhaps multichannel audio, which is very poorly supported by Ae, where you only get the first two channels?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
