Activity Forums Avid Media Composer No audio output when footage played in left/player window
  • No audio output when footage played in left/player window
    Posted by Mark Wagner on April 5, 2014 at 8:45 pm
    hi
    i am using Mediacomposer 6.5.3 running on OSX 10.7.5 with video and audio being output via a Bluefish Epoch card.
    when loading a clip into the left player window i can´t hear any audio. as soon as it is edited into the timeline i can hear the audio.
    any ideas?
    tried checking all setting but no luck yet : /
    Mark Wagner
    Colorado | Berlin
    John Pale replied 12 years, 5 months ago 2 Members · 5 Replies
  • John Pale
    April 5, 2014 at 8:59 pm
    Set your audio output to stereo instead of direct out, unless you are configured to monitor more than 2 channels.
  • Mark Wagner
    April 5, 2014 at 9:51 pm
    tried that already but wasn´t solving the issue.
    Mark Wagner
    Colorado | Berlin
  • John Pale
    April 6, 2014 at 2:33 pm
    Not familiar with the Bluefish card, but I’d start looking there. Does it have a control panel like the AJA or Blaxkmagic cards do?
  • Mark Wagner
    April 7, 2014 at 8:39 am
    so checked again and the problem only occurs when i import music from mp3 source.
    it just won´t play the audio (though the internal meter is showing signal) in the source window when the bluefish hardware is enabled.
    any other ideas?
    Mark Wagner
    Colorado | Berlin
  • John Pale
    April 8, 2014 at 12:52 am
    Try checking to make sure your import settings are converting the sample rate to your project setting (probably 48k).
    Many mp3 files are 44.1.
