Activity Forums Avid Media Composer No Audio Output
  • No Audio Output
    Posted by Danny Jenkins on January 8, 2009 at 11:47 pm
    I’ll try and describe everything as best as I can, but I’m relatively new to the avid system, so here goes. Please let me know if there’s any info I’ve missed.
    I have no audio coming from my Media Composer with mojo SDI (on a PC). Well there is audio coming out embedded through the SDI channels but no audio coming from any other outputs into my monitors. I can hear audio through headphones when I plug them into the avid hardware breakout box. I can also get audio when i patch it through SDI into a Sony DV deck.
    When I open up the audio Settings > Audio Project > Output tab, there is only a tab for SDI output. We have another Symphony Nitris System, and when I open up the same Settings window, there are also tabs for analog, digital & optical outputs.
    So somehow my analog output (used for monitoring) has disappeared?!
    It is the same for any project I open. I can however open the same project on the Symphony and it works fine.
    Things started going wrong when I was attempting to import an mpeg, which didn’t work, so I converted it in sorenson to an .mov. I had encoded the audio at a low bitrate so I did a re-encode of the audio. I think I tried the uLaw audio codec. When I attempted to import this clip, it seemed at this point I lost audio. I have no idea if this is a coincidence or not though.
    I hope you guys can help me out as I’m trying to get things back to normal before my boss comes back!
    Thanks, Danny.
    Danny Jenkins replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
