Activity Forums Adobe Premiere Pro No audio on the countdown leader?
  • No audio on the countdown leader?
    Posted by Phil Lister on September 9, 2024 at 2:36 pm
    No matter what I do, I can’t seem to get the cue beeps to play in the time line for the countdown leader. They don’t even show up as a waveform, yet, when I play the time line, the VU meters pulse up and down, as though the beeps are playing. Any ideas? Weird stuff! Even tried rendering and replacing the sound track…no sound. The color bars have tone though.
    Mads Nybo jørgensen replied 2 years ago 2 Members · 1 Reply
    September 10, 2024 at 9:39 am
    Hey Phil,
    Going out on a limb here, but your “waveform” when using tone would just be one straight line.
    Which, depending on your Zoom-View on the audio track, it might perfectly sit on top of where “the other line” is?
    What you want to watch on the meter, is if that is at a level where you want it to be?
    And, if it is there on the exported file, then you should be OK.
    Hope that this helps?
