Activity Forums Avid Media Composer No audio on Quicktime Reference export
  • No audio on Quicktime Reference export
    Posted by Victor Seckeler on April 3, 2014 at 6:13 am
    All of a sudden, there is no audio when I export a QuickTime Reference into Avid DVD. And in playing the reference mov on my desktop there is no audio there either. When I export a full QuickTime movie there is audio.
    I tried restarting the application, then the computer, deleting the MCState, the site attributes, making a different project. At one point there was an error code in the Media Composer: The error was: Exception: AMPI subsystem error, Error Message: DSMerrorcode eDSM error code eDESMError_SendMessageErr, AudioMixPateComponent::DisconnectOutputSection is Audio Mix Path.cpp:1034
    Any ideas most appreciated. Thanks.
    I am on Windows 7, HP Z820, Media Composer/Symphony 7.0.3
    Victor Seckeler replied 10 years, 4 months ago 3 Members · 6 Replies
  • Ricky Barrow
    April 3, 2014 at 11:34 am
    Is audio AMA linked? What is the media type … MXF? What are your QT Ref export settings?
    Ricky
  • Victor Seckeler
    April 3, 2014 at 1:38 pm
    The media is DNxHD 220 MXF. It’s 1080p 29.97. The QT settings are: export as QT ref. Use mark, enabled tracks. Flatten video tracks, fill spaces with black, render av video effects, mixdown audio tracks (there is only one on this project), audio format: WAVE, 48 kHz, 16 bit. Use Avid Codecs, RGB color levels. I’ve recently made many QuickTime reference movies successfully from footage from the same source with all of these same settings, and all of a sudden it’s stopped working = no audio.
    Victor
  • Ricky Barrow
    April 3, 2014 at 2:00 pm
    Looks like you’re doing everything correctly. Saw several posts about this so you might look into a few things:
    1 – See if you have any RTAS Plugins in use (a workaround may be to do audio mixdown)
    2 – On Windows 7, make sure DEP is disabled (right click My Computer, Properties, Advanced Settings, Performance
    3 – Short of fresh install you can try rebooting and/or try Programs and Features in control panel and “repair” Avid MC
    Google brought these up from Avid Knowledge base and Avid Community Forums as recently as Feb. 2014 – seems to be an intermittent bug, possibly corrupt drivers?
    Ricky
  • Victor Seckeler
    April 3, 2014 at 4:03 pm
    1. The audio is already mixed down; the video too. 2. It seems that I only have two options for the DEP. The one that is checked says it’s only used for essential uses. completely. 3. Since I can output a QuickTime movie with audio and am right now in the middle of a time-critical Bluray/DVD burn, I can’t check out the repair MC option now. I have restarted the computer numerous times.
    Thank you,
    Victor
  • Sarah Furie
    May 13, 2016 at 6:56 pm
    Did you get a fix for this?
  • Victor Seckeler
    May 13, 2016 at 7:04 pm
    I’m now on Symphony 7.04 and no longer have the problem. I had even forgotten about it, and have made several Quicktime Reference .movs in the past several weeks. It is only your post that now reminds me of it.
