Activity Forums Adobe Premiere Pro No Audio on MPEG in Adobe Premiere Pro 1.0??
  • No Audio on MPEG in Adobe Premiere Pro 1.0??
    Posted by Lars Stolte on March 19, 2007 at 4:04 pm
    I am using Adobe Premiere Pro 1.0 with a brand new HP 9260 with Windows Vista. I Encoded the MPEG in genereic settings for MPEG 2. The picuture is fine, however I can’t figure out why there is no audio. I did select both audio and video to be encoded. Is this is a Vista problem?? All your help is greatly appreciated! Thanks so much!
    Sincerely,
    Lars
    Lars Stolte replied 19 years, 5 months ago 5 Members · 6 Replies
  • Harm Millaard
    March 19, 2007 at 5:19 pm
    Even PP 2.0 does not support Vista, let alone PP 1.0.
    Did you expect Word 95 to run under Vista?
  • Mike Velte
    March 19, 2007 at 7:43 pm
    Smells more like you exported “elementary streams” (separate audio and video files} which is the default for Mpeg 2 for DVD. Look back in the same folder as your video for a .wav file of the same name…
  • Tvle2006
    March 21, 2007 at 12:02 pm
    I had the same problem with XP. I found the MPEG file and a wav file in the same folder. What should I set to create MPEG file with audio?
    Thank you
  • Geno Geng
    March 22, 2007 at 5:15 pm
    I am having this same problem…I see the wav file. How do I get this to work?
    thank you
  • Mike Velte
    March 22, 2007 at 5:55 pm
    Most DVD authoring apps expect 2 elementary streams…less sync issues.
    On the Export Setting page of Adobe Media encoder, select Export Audio and THEN about 75 pixels south of that button, click the Multiplex tab and choose DVD.
  • Lars Stolte
    March 23, 2007 at 7:50 pm
    You did it….thank you very much…it works!!
    Thanks again.
    All the best,
    Lars
