Activity › Forums › Apple Final Cut Pro Legacy › no audio on imported mpeg2
  • no audio on imported mpeg2
    Posted by Jim Brannigan on December 1, 2008 at 10:36 pm
    i imported an mpeg2 file into fcpro v6 and the audio does not play, and there is no audio tab in the viewer. however, when i play the clip from the desktop, the audio is there.
    any ideas why the audio is not playing in fc pro?
    thanks – jimb
    Jim Brannigan replied 17 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Russell Lasson
    December 1, 2008 at 11:55 pm
    It’s probably a muxed mpeg2 file. FCP won’t recongize the audio. Try using MPEG Streamclip to render to a different format or extract the audio.
    -Russ
    Russell Lasson
    Ridgeline Digital Cinema Mastering
    Universal Post
    Salt Lake City, UT
  • Chris Borjis
    December 2, 2008 at 12:50 am
    [Russell Lasson] “FCP won’t recongize the audio”
    most likely a Dolby audio track.
    if it was PCM (.aif or .wav based) it would work.
  • Jim Brannigan
    December 2, 2008 at 2:03 am
    thanks- upon further investigation it looks like it could be an mpeg2 muxed file. what would be the optimal format to re-format to ?
  • Rafael Amador
    December 2, 2008 at 2:18 am
    The MPG-2 with muxed audio contains MP1/layer2 audio, quite old fashioned and little efficient codec.
    Try converting to any format that don’t need to be re-render in FC; Aiff or Wave with the default setting.
    Rafael
    http://www.nagavideo.com
  • Chris Borjis
    December 2, 2008 at 9:17 pm
    [Rafael Amador] “The MPG-2 with muxed audio contains MP1/layer2 audio”
    only european dvd players can playback mpeg1/layer 2 audio.
    in the USA it can only be Dolby AC3 or PCM.
  • Jim Brannigan
    December 3, 2008 at 5:49 pm
    Thanks to all of you who have posted on this thread. i’m going to download mpeg streamclip and attempt to converr the file to a different format.
    cheers-jim b
  • Jim Brannigan
    December 4, 2008 at 2:16 am
    just wanted to report that clipstream worked great. i de-muxed the file and converted it. the new file imports and plays in fcp, video and audio (aiff). again, thanks to all for your posts.
    jimb
