Activity Forums Apple Final Cut Pro Legacy No Audio in Viewer Playback?
  • No Audio in Viewer Playback?
    Posted by Euan Preston on June 13, 2010 at 12:20 pm
    I’m in the middle of a project (FCP 7). All of a sudden, anything I load into the viewer has no audio – correction, it has no audio when I play it forwards. When I play a clip backwards I can hear it. The audio meters are showing that audio is there.
    When I edit the clip into the timeline, still no audio. The audio for clips I edited in earlier is still present and audible.
    I’ve gone through the process of trashing the prefs which did nothing.
    Any ideas?
    Edward Phillips replied 15 years, 6 months ago 4 Members · 8 Replies
  • 8 Replies
  • Euan Preston
    June 13, 2010 at 12:45 pm
    A few moments after making the above post, audio spontaneously returned. I edited an audio clip into my timeline and everything returned to normal.
    However, a few edits later and it’s done it again – no audio in the viewer and no audio when I edit a new clip into the timeline. Strikes me it must be a bug. Anyone have any experience with this?
    Ta.
  • John Fishback
    June 13, 2010 at 1:37 pm
    Have you trashed prefs & repaired permissions?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Euan Preston
    June 13, 2010 at 1:42 pm
    Hi John,
    Thanks for that. I’ve trashed the prefs, but how does one go about repairing permissions?
    Euan
  • Tom Wolsky
    June 13, 2010 at 2:15 pm
    Use the Disk Urility to repair permissions.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • John Fishback
    June 13, 2010 at 5:16 pm
    In Applications go to the Utility Folder. In there find Disk Utility. Start it and when the app opens, select your system drive and click Repair. There’s no point in doing a verify first as if you need repair you’ll have to click Repair anyway. That’s it. Here’s some info from Apple re Repair Permissions.
    John
  • Euan Preston
    June 13, 2010 at 5:29 pm
    Thanks guys. Repairing permissions yielded no joy, however the problem was solved when I selected all clips on my timeline, hit ctrl+c, created a new timeline, hit ctrl+v and deleted the original timeline. Obviously something wasn’t right with the sequence itself.
    Thanks again!
    Euan
  • John Fishback
    June 13, 2010 at 7:30 pm
    I’m glad you figured it out. While I don’t know if this would have helped, its a great FCS Maintenance Utility. Also checkout their Preference Manager. Also, Disk Warrior will keep your directories healthy. I run it once a month as preventive maintenance.
    John
  • Edward Phillips
    March 22, 2011 at 4:17 pm
    I know this is an older thread but in case any still has this issue. I could play audio fro the timeline, play backwards in viewer but not forward like the OP. I went to my sequence settings, clicked Audio Output Tab, and did nothing but hit okay. A warning came up saying the current audio device does not support the # of outputs. I clicked “Downmix all outputs to Stereo” and clicked okay. Everything works fine now.
