Activity › Forums › Adobe After Effects › No audio in Save RAM Preview CS3?
  • No audio in Save RAM Preview CS3?
    Posted by Scott Bush on November 12, 2007 at 11:22 pm
    So I just today had CS3 installed at work, and I am getting a strange (I think) issue. In AE7, when I chose Composition–>Save RAM Preview, I’d get a quicktime movie, with animation codec, and audio at 48khz. In AE3, I get the animation quicktime, but no audio. am I missing a setting somewhere or is this a new feature/bug? The audio plays fine when I PLAY the Ram preview (from the timeline), but when I SAVE it I get no audio. Any thoughts? Thanks,
    Scott
    AECS3, OS X 10.4.10, Quad G5 2.5ghz, 8GB Ram
    Simon Terrey replied 18 years, 4 months ago 4 Members · 4 Replies
  • Scott Bush
    November 13, 2007 at 5:11 pm
    Oh – guess not. Don’t remember ever doing that in 7, but you’re right! Thanks for jarring my sleepy brain!
  • Andrew Yoole
    November 21, 2007 at 7:52 am
    I’m experiencing this same issue on 5 various Macs (PPC and Intel) since installing CS3. All my systems have minimum 4GB RAM, and Decklink cards installed.
    The standard RAM preview Output Module has audio enabled anyway, but I’ve also created my own custom Output Modules with audio enabled, and have had no success. Intermittently the audio will suddenly start being saved with RAM previews during a session, but as soon as AE is restarted the problem returns.
    This has been occurring for two months since installation without resolution, and I’m amazed it hasn’t generated more discussion – surely I’m not the ONLY one experiencing this issue repeatedly? If so, what could be common to ALL my systems that’s causing the fault?
    Any input greatly appreciated.
  • Keeton Henderson
    January 11, 2008 at 3:41 pm
    I tried to render a RAM and I have the same issue, no audio. I checked and my audio option is on. Any solution is much appreciated.
    Keeton Henderson
    WMOR-TV32
  • Simon Terrey
    May 30, 2008 at 1:36 pm
    I’ve got the same problem in all 5 of our Intel G5’s running CS3.
    This is Adobe’s reply:
    Dear Mr. Terrey,
    I’ve had a reply from the research team and they have recognized your
    issue as a bug (reported in database as (#45802).
    They’ve checked the bug details and it looks like they have fixed this
    for the next version of After Effects.
    The only workaround with the current version of After Effects would be
    to duplicate the item in the render queue, after the first render. If
    you duplicate the item in the render queue (Apple + D) and then go back
    into the output module settings and turn audio on and then render it
    again it works. The resulting file will have audio. Only when rendering
    it the first time does the problem occur.
    Sorry for the inconvenience.
    Yours sincerely,
    Antoine
    Adobe Technical Support
