Activity Forums Adobe Premiere Pro no audio in quicktime
  • no audio in quicktime
    Posted by Mastar on November 18, 2005 at 12:33 am
    Hello people,
    I have imported a .avi file in Premiere Pro 1.5 and i want to export this file to a .mov file. The converting is oke, and the video file is aswell good, but i have no audio. I have checked everything concerning the audio but everything seems to fail. I’ve heard that this is a common thing with Premiere but is there a solution for it?
    Mastar replied 20 years, 9 months ago 2 Members · 2 Replies
  • Carl Marten
    November 18, 2005 at 1:54 am
    You could try using Sorenson Squeze. If you are editing in PPro export the sound and audio seperatly and combine them in squeze (hint it is the best quicktime app). If it is a strait conversion then pump the avi into squeze.
    If you realy want to get things working via PPro then export uncompresed audio and video seperatly, then in a new project (uncompresed settings) load your files and then try to export a .mov.
    The problem is often partialy compatibly codecs. You need to remove the guess work. (this happens most often with the mp4 codecs, divx, xvid etc or un-specified av combos)
    This problem tends to happen on a PC with loads of codecs instaled. Whilst files will play on the actual PC editing and recompressing are a pain.
  • Mastar
    November 18, 2005 at 12:12 pm
    Thanks for your help, Squeeze tends to crash when importing a 700mb file, so i can’t work with Squeeze.
    I will try the PPro method.
