Activity Forums Adobe After Effects NO AUDIO IN MY FINAL MOVIE!! :(
  • NO AUDIO IN MY FINAL MOVIE!! :(
    Posted by Esther Casas on April 26, 2008 at 9:40 pm
    Hi everyone,
    It might be very silly but I can’t find the way to get my final movie with sound…
    I am basically mixing 3 movies.I am importing two of them as .movs and one as .mp4 (all of them have sound). I don’t have the original sound tracks..and I didn’t think it was necessary as the quicktime movies have already the sound incorporated in it.
    When I do preview while working in AE i can actually hear the sound of each and mix it, but when I render and get the final quicktime there is no sound, I can’t find anywhere the option fo r it…i am sure is very easy but right now i don’t see it!
    Can someone help me on this please??
    Thank you all!!
    Esther
    Esther Casas replied 18 years, 4 months ago 2 Members · 4 Replies
  • Darby Edelen
    April 26, 2008 at 9:44 pm
    [Esther Casas] “but when I render and get the final quicktime there is no sound, I can’t find anywhere the option fo r it…i am sure is very easy but right now i don’t see it! “
    Click on the Output Module in the Render Queue (the part of the text that is in blue), then look at the very bottom of the dialogue box that pops up. Does the section labeled ‘Audio Output’ have a check mark next to it? You can choose your sample rate (48Khz is standard for DV), bit depth, mono/stereo and a codec.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Esther Casas
    April 26, 2008 at 10:06 pm
    Darby!
    how easy it was, can’t believe i didn’t see it!
    thank you so much.
    Bu the way,can I lower the volume when I want it during the movie even if I don’t have the original tracks?
    e
  • Darby Edelen
    April 27, 2008 at 4:16 am
    [Esther Casas] “Bu the way,can I lower the volume when I want it during the movie even if I don’t have the original tracks?”
    If a layer has audio you can keyframe the Audio Levels to adjust the volume. The shortcut to reveal this property is ‘L’ if you press ‘LL’ it will show you the waveform as well.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Esther Casas
    April 28, 2008 at 9:43 pm
    Darby, you are been a great help, got everything I need, for now..
    Thank you very much!
    Esther
