Activity Forums Adobe After Effects No Audio in After Effects Composition.
  • No Audio in After Effects Composition.
    Posted by Toby Dix on June 5, 2012 at 8:41 am
    When i import clips into after effects they have sound and when you play them they work find. But when i put the clips into an after effects composition they don’t have any audio, not even a waveform. I have done most of the basic stuff and it’s not a RAM preview issue i don’t think.
    I have tried using clips that have worked fine in the past and they lost their sound when they are imported into a comp. I have tried using wav formats for audio and they don’t work either. I have this problem when using after effects cs6 and cs5 on my mac. I even tried installing the trial on a windows partition and this did not work either and i had the exact same problem.
    Please help.
    Thanks.
    Aized Jamal replied 10 years, 9 months ago 6 Members · 8 Replies
  • 8 Replies
  • Angie Taylor
    June 6, 2012 at 11:07 am
    Hi there,
    Have you checked the Audio Hardware Preferences in AE? It may be that AE is automatically sending the audio to an installed device that you are not using? Try changing the Default Device menu to Built-in Output and testing it on the built in speakers on your system.
    Hope this helps
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Jan Janssen
    December 11, 2012 at 7:58 am
    same here… no audio what so ever,
    checked the preferences, and that’s fine , i really do not know what is going on
    reinstalled the program no result:
    please can anyone suggest some more idea’s also the very obvious ones so i can check them from my list
    super thanks 🙂
  • David Anzaldua
    December 12, 2012 at 2:24 am
    Could you tell me how to do this please i need to finish a project by tonight and i need audio!!!
  • Jan Janssen
    December 13, 2012 at 7:23 am
    to work around it is that you have to sync your timecode in your editing program and switch between the after effects and editing program (where you put your audio down) to sync..
    far from the ideal situation.
    Haven’t found a solution yet either, it’s driving me crazy..
    please advise
  • David Anzaldua
    December 13, 2012 at 10:38 pm
    well im not sure if its my video type or what cuz the type is AVCHD or .mts. Ok so for some reason when I put the videos in after effects the little box below where you toggle the audio on and off isnt even there, and when i put an audio file like a .wav or something it allows sound…ill show you a picture in the attachment
  • Aza Allen
    June 15, 2013 at 10:38 am
    I am having audio issues as well in AECS6! I know the audio is there, it works when I ctrl-drag over the timeline, but when I hit “0” or “.” on the Numpad, it won’t play!? I’m on Win7 x64
    My portfolio can be seen at http://www.ruesterprod.com
    My personal website is http://www.azaallen.com
  • David Anzaldua
    June 15, 2013 at 11:26 am
    I FINALLY FIXED IT!!!!!!! You just have to convert the video into a different video file like mp4 and it will work find, after effects takes away the audio for my type of video but not after you change it to another video file
  • Aized Jamal
    November 29, 2015 at 11:12 pm
    I am using CS6, when I add wave file in after effects cs 6 then put it on timeline!!! I did expended audio file from timeline like down arrow short key L I can see two green bar like mute but no waveform I played the audio through dot/ period button, it plays with the audio but it doesnt show me waveform
