Activity Forums Adobe After Effects No audio in AE CS3
  • No audio in AE CS3
    Posted by Accountclosed_no_realname on September 30, 2007 at 1:37 am
    I’m currently trying out a trial version of AE CS3 however I have a frustrating problem I can’t seem to figure out.
    If I import any type of video that has audio (or even if I just import audio, such as a standard WAV file) I cannot get the audio to play in AE. Everything else appears to work fine, but audio just wont play. I can view the waveforms, so I know AE knows it’s audio,
    Please help!
    PC Spec
    Pentium Quad Core processor
    2 gig RAM
    Soundblaster X-Fi soundcard
    Motherboard Intel D975XBX2
    Windows XP Pro SP2
    Ronald Lindkvist replied 16 years, 1 month ago 5 Members · 6 Replies
  • Steve Roberts
    September 30, 2007 at 1:21 pm
    There are two ways to play audio in the timeline:
    – hitting the . key on the numeric keypad (audio only)
    – making a RAM preview (audio and video)
    Hitting the spacebar won’t play audio. In case you hit the spacebar.
    Did this help?
  • Accountclosed_no_realname
    September 30, 2007 at 1:43 pm
    Thanks for the help Steve, that worked a treat.
  • Nicholas Toth
    October 1, 2007 at 1:18 pm
    Wow. The quicktime/itunes update destoryed audio playback in AE 7. This fixed it.
    https://www.wwug.com/cgi-bin/displaywwugpost.fcgi?forum=adobe_after-effects&post=070430181846.htm
  • Mats Sparby
    April 26, 2010 at 12:45 pm
    o it didn`t help:(
    I only hear sound when i press “ctrl” and “Alt” keys at the same time and drag the timeline indikator.
    Do you have solution?
  • Steve Roberts
    April 26, 2010 at 12:58 pm
    Are your audio files MP3? If so, then convert them to AIFF or WAV using Quicktime or something like that. Google “MP3 to WAV”.
    Can you hear sound when you play a rendered movie in Quicktime?
    Can you hear sound when you hit “.” on the NumPad?
    Can you hear sound when you make a RAM preview, with the audio button on in the playback controls panel?
  • Ronald Lindkvist
    August 11, 2010 at 9:40 am
    YES – helped me tremendeously.
    Br
    RealityRon
