No Audio in 1h long video no matter what format it’s rendered in
Hi guys,
I was finishing my 1 hour long stream video an music album complication. There are 16 tracks of which 14 are .wav files, one MP3 and one mp4 video at the very end. When I try to render it as a video in .wmv (tried mp4 but no audio either. Can’t use mp4 though because it would be 15GB worth of a video) it doesn’t give me the audio at all, atleast not in the beginning. I didn’t render the whole video just the first 10-15 seconds to check if audio is there but it never is or it’s just some kind of quiet distortion like you would play just the first second of a song and repeated it.(What also happend is that it picked a song in the composition and made a perfect 2 second loop for the six minutes)
This goes on for like 6 minutes after that the audio plays normally, that’s what I found out as I tried to render the whole seperate 15 tracks into one .wav. When I shift the audio files so that the first track is at the 6th minute and render all of it (even the 6 minutes of silience at the beginning) the whole audio is just fine. But that doesn’t work when I try to render it in a video. It just never gives me the audio. Doesn’t matter if I put the composition directly to Media Encoder or render it first in AFter Effects itsself as a AVI (which was 396GB by the way) and then put that into a composition with the audio and then into Media Encoder.
