Activity Forums Adobe Premiere Pro No audio from multi-cam clip in Source window, nor in Timeline window, but works in a Sequence (PP cc 2017)
  • No audio from multi-cam clip in Source window, nor in Timeline window, but works in a Sequence (PP cc 2017)
    Posted by Elias Gwinn on February 27, 2017 at 5:03 am
    THE PROBLEM: the audio of multi-cam clips isn’t coming out of my audio hardware interface, EVEN THOUGH the meters show activity. Specifically:
    – When adjusting a multi-cam clip in the Source window, there’s no audio (again, I can see audio in the meter). When I drop that clip into a sequence, I can hear the audio from that multi-cam clip.
    – When adjusting a multi-cam clip in the Timeline, there’s no audio (again, I can see audio in the meter). When I drop that clip into a sequence, I can hear the audio from that multi-cam clip.
    – I CAN hear the audio from normal video clips (NOT multi-cam) playing in the Source window
    – When I switch the audio hardware from my interface (see below) to the Mac Pro’s ‘Built-In Line Output’, everything works as expected.
    My audio interface is a MOTU 828 Hybrid mk3. I send all my computer’s audio out the TOSLINK output. I have no problems with any other source – only when viewing multi-cam clips in the Source window and the Timeline. Again, the meters indicate there should be sound, and those same multi-cam clips play audio fine when in my sequence.
    I tried experimenting with ‘Output Mapping’ in PP’s ‘Audio Hardware’ settings panel. Nothing I tried fixed it.
    Any ideas?
    Elias Gwinn replied 9 years, 6 months ago 1 Member · 1 Reply
  • Elias Gwinn
    February 27, 2017 at 6:15 pm
    Anybody have any ideas what the problem might be??
    Many thanks in advance!
