Activity › Forums › Adobe After Effects › No audio during RAM Preview
  • No audio during RAM Preview
    Posted by Gary Madison on July 13, 2012 at 7:43 pm
    Hi Everybody
    No audio during RAM Preview in CS6. Will preview audio alone but not simultaneously with composition video. Either Video or Audio will play but not both at the same time.
    Using internal speakers on this first run of trial software.
    All other apps that use audio are playing.
    gary
    Rune Glad replied 13 years, 11 months ago 5 Members · 11 Replies
  • 11 Replies
  • Cassius Marques
    July 13, 2012 at 7:50 pm
    How are you previewing audio alone? hitting “,”?
    Have you checked if the “mute audio” button ain’t pressed on your preview tab?
  • Gary Madison
    July 13, 2012 at 7:59 pm
    Hi
    No mute. Tried both on and off.
  • Cassius Marques
    July 13, 2012 at 8:04 pm
    no solo switches on? Have you tried different audio files? Restarted machine?
    can you post a screenshot…I’m just trying to narrow it down.
  • Gary Madison
    July 13, 2012 at 8:18 pm
    Yeah, tried a couple different clips. Waveform shows up. Will repair the permissions and restart.
    Thanks for you input I’ll be right back.
    Best gary
  • Gary Madison
    July 13, 2012 at 8:46 pm
    Still no audio, here’s the screen shot. The upload file says file type not supported. Used grab for screenshot
  • Kevin Camp
    July 13, 2012 at 9:25 pm
    check composition>preview and make sure that ‘audio’ has a check mark next to it. if not, select it to activate audio for previews.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Gary Madison
    July 13, 2012 at 9:33 pm
    Hi Thanks
    it’s checked
  • Gary Madison
    July 13, 2012 at 9:35 pm
    h.264, (Canon 5d mkII) Has always worked before. Audio is checked in the Comp preview
  • Gary Madison
    July 13, 2012 at 10:49 pm
    It’s a screen shot, I used Grab (Mac) to capture it.
    Sorry about the last post.
    Still no audio in AE CS6 on RAM Preview. Thank you for your time and input.
    gary
  • Richard Brooker
    September 7, 2012 at 11:18 pm
    Your post just helped me out – thank you! Yes, audio has to be selected with a check mark next to it. Sheesh! Usually it is by default.
    Richard B
