Activity Forums Apple Final Cut Pro Legacy no audio after exporting out of compressor
  • no audio after exporting out of compressor
    Posted by Tarponater on July 25, 2007 at 11:07 pm
    I exported my project using compressor….Im using the Mpeg 2 settings (Best Quality) when its finished compressing, when I open the file, theres no audio attached, nor can I find it…..The sequence in FCP has two channels of audio….any thoughts????
    Im trying to author the DVD in DVD SP
    Chris Poisson replied 19 years, 2 months ago 3 Members · 4 Replies
  • David Roth weiss
    July 25, 2007 at 11:16 pm
    Are you using FCP 5 or 6? They bot work slightly differently, but in both cases you must choose audio export as well, preferably AC3 for most cases. Did you do that?
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Tarponater
    July 25, 2007 at 11:48 pm
    Im using FCP 5 and no, I did not do an audio export seperately….how do you do this using compressor??
  • David Roth weiss
    July 26, 2007 at 12:31 am
    When you look in the folder for the MPEG2 preset you chose, there will also be one for aiff audio and one for ac3. Choose the ac3 in addition to the MPEG2 next time and Compressor will do both for you as a batch. This time you can just go back and select the ac3 audio only inside the proper preset folder.
    Hope this makes sense…
    David
    David Roth Weiss
    Los Angeles
  • Chris Poisson
    July 26, 2007 at 3:48 pm
    Audio and video are separate files for DVD production. In Compressor you choose either aiff or AC3 as David says.
