Activity Forums Blackmagic Design No Audio
  • Posted by Jeffrey Ellis on January 10, 2009 at 7:47 am
    I’m a bit confused. I was told by TS that I wanted to capture using component video and the breakout cable. I hooked up the cables as instructed. But when I go to the Decklink control panel, there are only Y, R-Y, B-Y and AES/EBU or Y, R-Y, B-Y and Analog XLR. Since the breakout cable with RCA jacks is the one for component video, and my audio source is analog, how do I do the capture? Or am I just missing something?
    Jeffrey Ellis replied 17 years, 8 months ago 2 Members · 2 Replies
  • Chris Pearse
    January 12, 2009 at 3:17 pm
    Hi Jeffrey,
    In the Decklink Control Panel, the ‘Y, R-Y, B-Y and Analog XLR’ is the option you require for component and analog audio, whether you are using the BNC or RCA breakout cables. This is because the pins on both breakout cable connectors are essentially the same. Both cables are provided so that you can connect to virtually anything you might need to.
    Chris Pearse
    Technical Support Consultant
    Blackmagic Design EMEA
  • Jeffrey Ellis
    January 13, 2009 at 5:27 pm
    Ah. That’s got it working.
    Thanks very much, Chris.
    Jeffrey
