Activity Forums Apple Final Cut Pro Legacy No Apple Pro Res 422 in mpeg streamclip
  • No Apple Pro Res 422 in mpeg streamclip
    Posted by Wesley Cordell on September 20, 2012 at 4:28 am
    Hey guys,
    I’m really stressing. Just bought a new canon and am delving into the DSLR world. Very exciting stuff.
    I have been suggested to time and time again to convert to apple prores 422 using mpeg streamclip. But that doesn’t seem to be an option.
    Step 1. batch list
    step 2.add files/export to quicktime
    step 3. is the problem
    I’ve looked over the codecs again and again apple prores 422 isn’t in there.
    I could really use some help and need a solution quick. Thanks guys
    Wesley Cordell replied 14 years ago 3 Members · 3 Replies
  • Rafael Amador
    September 20, 2012 at 11:13 am
    I’ve got all the Prores flavors there.
    Some old MPGStreamclip version didn’t tag properly Prores/Prores HQ.
    Do you have the last version installed?
    rafael
    http://www.nagavideo.com
  • Quentin De fouchecour
    September 20, 2012 at 2:24 pm
    you must ahve other programs using apple prores codecs so unfortunatly you have to install final cut pro just for that..
    then mpeg streamclip will use the codecs you have along with fcp
  • Wesley Cordell
    September 20, 2012 at 3:25 pm
    Hey everyone.
    I stayed up late and figured this out. I’m not sure what the problem was honestly.
    But I just installed trail fcpx and then downloaded apples pro res. You can get it from their site. (then deleted X, because it’s awful)
