Activity › Forums › AJA Video Systems › No analogue audio out of KBox
Posted by John Davidson on August 27, 2005 at 11:37 pmI’m sure it’s user error, but I can’t seem to get analogue audio out of my kbox/Kona2. I can get sound if I select ‘built in audio’ and play out of the mac, however the whole sell of the kbox was the analogue out.
The seller even sold me a 35 buck cord that I needed to plut analogue out into my mixer, so I know it’s supposed to work.
I set the a/v prefs to Kona 2 out as well, so I’m at a loss.
Any ideas?
Bob Zelin replied 21 years, 1 month ago 4 Members · 9 Replies -
David Battistella
August 28, 2005 at 12:17 amthe only analog out of the Kbox is the two rca connectors (red and white). That’s it! Everything else is digital.
David
Many people use a flying cow box by M-Audio to convert the digital Audio to analog or they use a digital mixer.
John Davidson
August 28, 2005 at 12:43 amThat’s right – and those two RCA analogue outs aren’t working, which is why I’m confused.
Aja Sales department
August 28, 2005 at 6:02 amHi-
If you have checked your cabling, etc. and you still have a problem, please feel free to contact our tech support group, and they can assist you. All of our Desktop products carry a 3-year warranty, as well as technical support via phone or email.
+1 (530) 271-3190, or support@aja.com
Thank you,
AJA Video Systems
(530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com -
John Davidson
August 28, 2005 at 10:15 amI’ll keep trying to figure it out. I’m wondering is the RCA outs of the KBox are SMPTE and not analogue…
John Davidson
August 28, 2005 at 10:15 ambut if I haven’t made some stupid mistake, I’ll call.
August 28, 2005 at 3:18 pmThe RCA connectors are unbalanced analog audio.
AJA Video Systems
(800) 251-4224 US
sales@aja.com -
Bob Zelin
August 28, 2005 at 8:03 pmHey JNeo –
I urge you to contact AJA support or hire an outside engineer or technician to come in and help you at this point. Your reseller sold you $35 cables – hopefully they should be able to send someone in to help you.
The AJA K-Box RCA connectors are analog audio outputs that will output ANALOG audio from your HD or SDI timelines. Right now, simply bring up color bars and tone internally from Final Cut Pro, and let it play out. You should for right now use an EASY SETUP selection, to make sure that your Audio/Video settings are set correctly, and that one of the tabs is not set incorrectly. Take the K-Box RCA outputs, and with the other end of your cable (which better be a 1/4″ stereo phone plug if it’s going into your mixer) – stick this end into one of the line inputs of your audio mixer. When you raise the faders, and you are letting the BARS play on the timeline, you should hear tone.
There are SO MANY VARIABLES that can be wrong without seeing your system. I have done so many silly things myself, like accidentally going into the INSERT INPUTS of the audio mixer, instead of the line inputs, etc. that will prevent you from hearing the audio. If you have a CD or Cassette audio player lying around, try plugging in the RCA connectors that go into the K Box, into a CD player, etc. – just to make sure that the cables are ok, and that you can HEAR the CD player (or cassette player).
Assume nothing.Bob Zelin
John Davidson
August 28, 2005 at 9:04 pmI am a moron.
I had them plugged into the wrong input on my mixer.
Broadcast degree and 10 years of experience folks – look where it gets me.
Thanks guys!
Bob Zelin
August 29, 2005 at 11:36 pmI am doing this for over 20 years, and recently plugged into the insert inputs instead of the mixer line inputs, and things didn’t work. So the moral is – the more experience you have, the bigger the moron you are, and no one is as big a moron as me. Glad you found the “problem”.
Bob Zelin
