Activity › Forums › Apple Final Cut Pro Legacy › no 3rd party(decklink or the like) card-uncompressed motion comps in dv time line?
  • no 3rd party(decklink or the like) card-uncompressed motion comps in dv time line?
    Posted by B Clark on April 15, 2005 at 5:46 pm
    No need for a decklink card at home but sure would like to have better than dv quality graphics in my timeline. How do I set up a FCP project to work with say uncompresed motion/AE comps and use dv footage in the timeline?
    -Bill
    Walter Biscardi replied 21 years, 5 months ago 2 Members · 3 Replies
  • Walter Biscardi
    April 15, 2005 at 6:15 pm
    Simply change the codec to Uncompressed 8bit (or 10bit) and change the frame size to 720×486. BUT without fast enough drives you won’t get any realtime playback of your files, nor will you be able to play them out to a monitor in uncompressed without at least an AJA Io.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • B Clark
    April 15, 2005 at 9:56 pm
    Are firewire 800 or internal ata drives fast enough for rt or do you need scsi ? I’m runnung a dual 1 gig g-4 and getting plenty of realtime in motion/fcp ( I have an upgraded radeon pro vid card) with internal ata. Also, what’s your recomendation for a cheap card to get ntsc playback with 8/10 bit uncompressed graphics and mostly dv footage?
    Thanks for your help,
    -Bill
  • Walter Biscardi
    April 15, 2005 at 10:01 pm
    Firewire 800 drives work if they are dual drive units like the G-RAID and the LaCie Big Disk Extremes. Those have two drives in each unit which are striped together.
    [bclark] “Also, what’s your recomendation for a cheap card to get ntsc playback with 8/10 bit uncompressed graphics and mostly dv footage? “
    Either the AJA Io LA or the Aurora PipePro. The Aurora has probably the best uncompressed codecs in the business.
