Activity Forums Adobe After Effects No 3d with precomp – layer always on top
  • No 3d with precomp – layer always on top
    Posted by Kenneth Tolaas on January 28, 2010 at 12:52 pm
    Hello, I am having a little trouble with 3d here.
    I have made a 3d-ball by turning a circle on its different axis. I then precomp these layers, and turn on 3d and Collapse Transformations (the star/sun symbol) on the new comp-layer.
    I now have a 3d-ball comp, but the thing is that its position in 3d-space is dependent on its layer-number, and not its real 3d-position.
    I get this line where it should say continued rasterisation and motion blur, I dont know if this has got anything to do with it..?
    Thanks for any help.. =)
    Kenneth Tolaas replied 16 years, 3 months ago 2 Members · 2 Replies
  • Todd Kopriva
    January 28, 2010 at 6:56 pm
    See if this page helps: “3D layer interactions, render order, and collapsed transformations”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Kenneth Tolaas
    January 28, 2010 at 7:09 pm
    Thanks. For now I just parented the layers together, and put most of them in shy mode.
    But I’ll use your link if I cant do that sometime later.
    Thanks again,
    -Kenneth
